pubpurc
Jun 10, 2021Aspirant
EAX20 AX1800 how can I change the security type
When my iPhone 12 Pro is connected to the extender, the phone tells me that the connection has a weak security. I tried to find out the security type ie. WPA, WPA2 or WPA3 on the extender. The Wireles...
Jun 11, 2021Guru - Experienced User
If you set it up using wps, it uses the same security of your router.
You can factory reset and extender and reinstall it using the installation assistant if you'd like.
Check the security on your router as well.
- pubpurcJun 18, 2021AspirantThanks for the suggestion. In fact the security type can be set manually when I create a new password for the bands instead of using the same passwords as the router.
