TeamTricky
Mar 01, 2023Tutor
EAX20 AX1800 web page "Settings +" button does not expand to show sub menu items
Just purchased the EAX20 AX1800. It seems to be working just fine, and I am happy with it. When I login into the web page from one PC, the "Settings +" and the "Do More +" buttons do NOT work. ...
- Mar 01, 2023
No clue why its working on one device and not the other.
You can try clearing cache/cookies and see if that helps
Mar 01, 2023Guru - Experienced User
Try a different web browser on that pc.
TeamTricky
Mar 01, 2023Tutor
Good idea.
I tried Microsoft Edge, and it worked. This is the first time I ever launched Edge on my PC. I always use Chrome.
So any ideas as to what would cause this to work with Chrome on one PC, but not another?
Both PCs are using the same Chrome Version 110.0.5481.178 (Official Build) (64-bit)
- plemansMar 01, 2023Guru - Experienced User
- TeamTrickyMar 03, 2023Tutor
I can't believe it by I cleared the cache and cookies, and now the Settings + menu works.
I am surprised by happy.
- plemansMar 04, 2023Guru - Experienced User
Its the little things that cause issues 🙂
