Kman1
May 24, 2022Aspirant
EAX20 Extender is setup. Downloaded app and it wants to repeat setup?
Latest firmware on my EAX20 Extender. Using as an access point. All setup using Ethernet, then that quit, and I was able to use my iPhone to finish. Had to enter SSID's twice, once on my laptop, whic...
May 24, 2022Guru - Experienced User
The app should autodetect that its already setup and you're connected. I'm surprised it didn't.
I've actually used that method before to test out my EX8000.
If it was me? I just wouldn't use the app. But its not really a fix.
You can try the factory reset and reinstall through the app if you'd like.
- Kman1May 24, 2022AspirantThank you for the reply. I deleted app and downloaded again. This time I got logged in, and to the point of app connecting to extender. But it will not connect. I’m standing 3 feet away, and on the extender Wi-Fi with my phone. On the 5g, and guest network is off. Logged in using Safari, and It says all is well, and access point is functioning. I’m with you, I won’t use the app. This method gives me access to what I need. Thank you again!
- plemansMay 24, 2022Guru - Experienced User
If you're on ios, make sure icloud relay is disabled. Same with random mac/ip address. They can cause issues on the app
- Kman1May 24, 2022AspirantI don’t have iCloud Relay, as I’m still using free 5Gig plan. It says it’s in beta, and included if I upgrade to 50Gig plan. I turned off Private Wi-Fi. Downloaded app and it still won’t connect. There’s an issue if I’m on the Wi-Fi network of extender, and the application can’t find it. It shouldn’t be that difficult. My Linksys AX1800 model MR7350 app will connect thru it’s app, even if I’m on the extender network. But I’m on the same network, and Nighthawk app can’t find it’s own unit. That’s a bug. And it’s annoying to have to change settings, and it still can’t locate the Mothership! Appreciate the help. It’s easier to use Safari and Netgear setup URL. Connects every time. Thank you again!
