tafkaltlg
Sep 17, 2022Tutor
EAX20 extender networks setup but no internet
New Netgear Nighthawk EAX20 extender, ran setup with wizard, installed fine. Extender found and connected to Motorola MT8733 no problem. Devices connect to extended networks ok, but no internet....
Sep 17, 2022Guru - Experienced User
What happens when you factory reset and run setup using the WPS push button method?
(it'll have the same ssid as the router so won't show up separate as WPS installs in mesh mode)
