tafkaltlg
Sep 17, 2022Tutor
EAX20 extender networks setup but no internet
New Netgear Nighthawk EAX20 extender, ran setup with wizard, installed fine. Extender found and connected to Motorola MT8733 no problem. Devices connect to extended networks ok, but no internet....
Sep 17, 2022Guru - Experienced User
What happens when you factory reset and run setup using the WPS push button method?
(it'll have the same ssid as the router so won't show up separate as WPS installs in mesh mode)
tafkaltlg
Sep 18, 2022Tutor
Factory re-set,
setup using WPS, both 2.4 and 5g networks and guest networks appear, broadcast and can be connected to- but still no internet
- plemansSep 18, 2022Guru - Experienced User
I don't believe you reran setup or it didn't reset properly. (not saying you didn't do it, just something wasn't done right) Reason I say that is the default option when you setup using WPS is the "one wifi" option where it has the same ssid as your router that you're connecting to. Yours is setting up with the _EXT extension. Which isn't default.
What router are you connecting to?
What modem/gateway is the router connected to?
did you go in and set a static ip address?
- tafkaltlgSep 19, 2022Tutor
hey, I really appreciate your help!
I did do the wps setup/ 'one wifi'... had connection between extender and modem/router fine again- but still no internet.
It showed as having the _ext extension because I had renamed to further diagnose each network.
Re-did, again... this time, followed your advise of the static IP - not too knowledgable about that- but guessed setting the static ip to the extenders IP and then I had to enter the gateway IP- which I was guessing was the motorola modem/router I wanted to extend? And the primary DNS? Guessed again at IPv4 DNS, (not the IPv6 ?)
Hoping that did it. Seems to be working now. Going to move the extender to its final location tomorrow- fingers crossed.
- tafkaltlgSep 20, 2022Tutor
Nope-
still not working!!
When I get to an area the extender covers, I show full connection to router, but no internet....
Any last suggestions before i return this thing?
