Jim-1021
May 09, 2020Aspirant
EAX20 extender will not connect
My EAX20-100NAS AX1800 connects but has no internet. Tried for 5 hours
May 09, 2020Guru - Experienced User
What router are you connecting to?
Are you setting up via wps or the installation wizard?
I'd recommend the install wizard and not wps.
What firmware is on the extender?
How have you tried installing and what steps have you tried? "tried for 5 hours" doesn't tell us much.
- Jim-1021May 09, 2020Aspirant
I have the Spectrum router Askey RACZU1K, I also have been online with a netgear support for over an hour. We reset the extender typed in the ip in the web address to enter setup. Went through every step and it finally showed up in the selections to choose from. But still says connected not internet secured. The netgear rep got fed up and said send it back.
- plemansMay 10, 2020Guru - Experienced User
Are you sure thats the model number of the router? I couldn't find any info on that model.
If its the: Askey RAC2V1K then its a model with known issues with extenders. and not on just netgear. see: https://community.tp-link.com/us/home/forum/topic/159613
- hmcdaniel11Jul 04, 2020Aspirant
AX1800 will not connect "Unable to find router". Attempting to Connect to Comcast XFSETUP-7478
- plemansJul 06, 2020Guru - Experienced User
hmcdaniel11 wrote:AX1800 will not connect "Unable to find router". Attempting to Connect to Comcast XFSETUP-7478
please start your own thread instead of jumping on someone elses. Then we'll be happy to help.
