Bwbakken
Oct 19, 2022Aspirant
Eax20 extender won’t work with frontier communications router
Anyone know why. My linksys extender works but not netgears.
Oct 19, 2022Guru - Experienced User
Where does it fail in the process?
Does not work doesn't tell us much.
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
If its new, you can contact support for free.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
- BwbakkenOct 19, 2022Aspirant
Netgear said the frontier modem didn’t have enough security so the extender wouldn’t connect?
- plemansOct 20, 2022Guru - Experienced User
1. Most people don't actually contact netgear if they googled for a number. They get a scam site that sells firewalls/security.
2. What security is being used on the frontier router and what frontier router is it?
3. What happens when you attempt setup and what method of installing are you using?
- BwbakkenOct 20, 2022Aspirant
It was designed by greenwave systems. Model number fios-g1100.
