tbonesullivan
Jul 12, 2021Tutor
EAX20 Orange Power Light - Won't Boot
I recently got an EAX20 from Amazon, and didn't get to set it up for 2 months after I got it, so of course it's out of the amazon return window, and their support was not helpful. The first time I p...
- Jul 14, 2021
Warranty is a good choice if you have it
Jul 12, 2021Guru - Experienced User
Many things can go wrong with tftp as well as there's a short window in which to execute.
You used the correct guide.
did you enable tftp:
make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
tbonesullivan
Jul 12, 2021Tutor
Ok. I tried multiple different IP configurations, as described in the youtube.
Using windows TFTP client, I saw "Connect Request Failed" after every time. I waited until the 10 flashes and released the button.
Also, about 30 seconds after powering on the extender, I lose the link light on my computer. With no link there is no way that I can make any type of transfer.
I looked at nmrpflash, and that's definitely not something I'm able to get working. It's still under warrantee, so I'm going to start a return claim. Not exactly happy that a brand new thing I never once used was DOA and even somewhat advanced salvage processes are not working.
- plemansJul 14, 2021Guru - Experienced User
- tbonesullivanJul 14, 2021Tutor
Should have it, it is still within 90 days of receipt. Thanks again for all the help.
