pulkitkhanna
Jul 19, 2023Follower
EAX20_unable to open banking apps on wifi extender network
Hi All, I recently upgraded my home network with an EAX 20 wifi range extender, however as soon as I join to the extender wifi network, my iPad and mobile banking apps stop functioning. Smart...
Jul 19, 2023Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
