hishinko95
Mar 17, 2022Aspirant
EAX20 Wi-Fi Extender cannot communicate with RAX40 Router
Hi Everyone, I've been having trouble with my extender communicating with my router, it appears to be a firmware issue. Every time I upgrade my router to the latest firmware (1.0.4.102), I lose over...
Mar 18, 2022Guru - Experienced User
so its only when you upgrade the router's firmware that there's issues?
If so, I'd leave it on the older version until a new one is released.
Are you setting up the extender with wps or the installation assistant?
Have you checked if that makes a difference.
- hishinko95Mar 18, 2022Aspirant
Correct, only when I upgrade to the latest firmware.
I tried setting up the extender both with wps and the installation assistant. No difference.
Thanks.
