Mark500000
Jun 22, 2023Tutor
EAX20 wired and in router mode
I was running my EAX20 in router mode and needed more signal in one area of our house. I wired it with Ethernet and moved it. It is still in router mode, not AP mode. Is the wired connection helping?...
schumaku
Jun 23, 2023Guru - Experienced User
Honestly, I failed to spot any indication of the EAX20 Router Mode in the fine manuals.
Of course, I'm aware the similar WAX202 and WAX206 Wireless Access Points can be configured into a Router mode, so don't wonder a second if they have enabled this (in my reading) undocumented feature on the EAX20, too..
In Router Mode, The AP functions as both a lightweight router and WiFi 6 access point, and can support LAN clients through its LAN ports. Because the AP is connected to your modem, the AP receives its IP address settings from your Internet service provider (ISP). The AP delivers IP address settings to its clients so that Internet access is provided.
The only meaningful purpose is to connect the WAN /Internet port to a cable modem (or the like). Other variants don't make much sense, due to double NAT, port forwarding limitations, ...
Do you have another NAT router, e.g. an ISP provided Wi-Fi router gateway combo?
Of course, you could re-locate the EAX20 in router mode to a position providing better WiFi coverage, by adding a cable connection to your internet device/cable modem. This requires that you have to extend all Ethernet cables for the LAN devices to the same position.
However, I'm not convinced this makes a lot of sense, depending on your Internet connection. If you have another NAT router/gateway offering private RFC1918 IP addresses for the LAN, consider to operate the EAX20 in access point mode.
- Mark500000Jun 23, 2023TutorI had ATT 300/300 fiber installed and ATT supplied the Humax modem/router.
The EAX20 is in router mode. The manual only says that running the EAX20 in AP mode results in losing some features of the EAX20, like guest access.- plemansJun 23, 2023Guru - Experienced User
Mark500000 wrote:
The EAX20 is in router mode. The manual only says that running the EAX20 in AP mode results in losing some features of the EAX20, like guest access.There is no router mode. So if it's not in access point mode, its in extender mode.
It won't function properly in extender mode if you have it hardwired to the router.
So if you want to wire it to your router, set it up in access point mode.
If you want to continue using the extra features, then you need to disconnect the connection back to the router and run it in extender mode.
- schumakuJun 23, 2023Guru - Experienced User
The EAX20 is in router mode. The manual only says that running the EAX20 in AP mode results in losing some features of the EAX20, like guest access.New guess from Switzerland: We're facing a RAX20 — 4-Stream AX1800 WiFi 6 Router here?
- Mark500000Jun 23, 2023TutorWhen I installed it, the EAX20 asked if I wanted to install the EAX20 in router mode or AP mode. I want sure so I picked router mode. I can’t find that in the manual. Maybe router mode means the same as extender mode.
Is there a reliable way to determine if the EAX20 is operating in extender mode, possibly router mode, or in AP mode?
