Mark500000
Jun 22, 2023Tutor
EAX20 wired and in router mode
I was running my EAX20 in router mode and needed more signal in one area of our house. I wired it with Ethernet and moved it. It is still in router mode, not AP mode. Is the wired connection helping?...
Bouncingmolar
Apr 01, 2024Aspirant
What does schumanku mean when it won't function correctly when connected to Lan in extender mode.
Does Lan connected AP mode still extend the wifi? Or does it need it's own separate wifi name
- plemansApr 02, 2024Guru - Experienced User
Bouncingmolar This post starts off with a few issues. I'd recommend starting your own if you have questions about a setup, performance, etc. then we can directly help you with your specifics and not get them confused with the OP.
