klockk
Nov 06, 2022Aspirant
EAX80 - 2.4Ghz Radio Power non-existent
I have had an EAX80 for a while no, but it's been giving me issues for a while too. It seems to only be able to connect to my primary network on the 5Ghz band. The only time it will connect on the 2....
Nov 07, 2022Guru - Experienced User
How are you scanning this?
Reason I ask is its a mesh extender. meaning it combines the 2.4ghz and 5ghz ssid into one ssid. Unless you disable that feature, standard built in scanners won't see it as a separate network
klockk
Nov 07, 2022Aspirant
Using WiFi Analyzer on my phone, looking at the specific MAC address for the 2.4Ghz bandnon the extender vs my primary router... And yes, I do have my SSIDs separate for 2.4 vs 5Ghz bands... always have, as my 2.4Ghz network is congested (one of the reasons for the extender) and I wanna force devices that can support 5Ghz to the 5Ghz band to free up the 2.4Ghz Band..
- plemansNov 08, 2022Guru - Experienced User
Have you tried a factory reset and reinstall using the installation assistant?
What firmware are you on?
What router are you connecting it to?
Do you have screen snips of what you're seeing?
