jvogal70
Feb 22, 2020Aspirant
EAX80 - 5ghz weak signal when using 5ghz 160HT mode on RAX120 router
I have an RAX120 router and just received an EAX80 range extender. Upon setup I noticed that when I have AX Enabled w/2.4 & 5 ghz OFDMA enable + the 5ghz mode (up to 4803 Mpbs (11ax, HT160, 1024QAM)s...
jvogal70
Feb 23, 2020Aspirant
Now it is dropping WiFi signals all together and some devices are not even able to connect. I am returning it and going back to using my EX8000 Range Extender. This RE is a piece of garbage.
david85297
Feb 24, 2020Star
I've had this issue since November 2019. They sent me a replacement back in November after spending an hour with support. Doesnt matter if its 2ft away, it will just drop connections. Getting a replacement will not fix the issue, it's a problem with all EAX80's.
I have an rax120 too, so it could be an issue when paired with the rax120. Little disappointed they havent had a firmware update to fix this issue that has been reported doe months.
- david85297Mar 10, 2020Star
Does anyone know if Netgear plans on fixing this issue? I'm so confused on how their site is showing good reviews for this product when it clearly doens't work. I've gone through 2 of them, and have had the same issue.
- pdfr99Jun 05, 2020Aspirant
I am having the same issue, but mine is connected to the RAX200 - This is just not a good extender if it is dropping connections all the time on the link between the two.
I submitted a warranty claim to have mine replaced.
- WilzGearJun 14, 2020Aspirant
Equipment...
RAX120
EAX80
Centurylink 1gb internet connection
Setup using a Windows 10 PC with Chrome broswer
Wifi Analyzer App from the Windows Store
...The Nighthawk app setup on my Samsung S5e tablet does not work correctly. I used the install assistant from the RAX80 through Chrome on a Windows PC.
I confirm the same problem and flaw in the EAX80. The EAX80 does not fully function at 160hz.
Setting the wifi mode to HT160 on the RAX120 yields only seconds of 4300mbps+ on the EAX80 then drops to 108mbps with a red router link lIght on the EAX80 extender.
The only working setup I found:
Setting the RAX120 5ghz mode to HT80 will get the EAX80 5ghz connectiion to the RAX120 working at up to 2400mbps with sustained connections.
