strakerc
Aug 23, 2020Aspirant
EAX80 - Cannot Access Settings
Man oh man, I have so many issues with my EAX80 / AX6000 Nighthawk Mesh Extender: 1. http://mywifiext.local/ loads, but clicking on the button "New Extender Setup" does nothing on Firefox, Chrome, o...
strakerc
Aug 24, 2020Aspirant
Thank you for the reply. Your idea about in-app updates works for my router, but not for the Mesh Extender I am asking about. If you switch products to the extender and then follow the same steps, there are no "Router Settings" - just "WiFi settings."
strakerc
Aug 31, 2020Aspirant
I'm a bit desperate for a solution - I just tried upgrading my router to a Nighthawk X6S / AC4000 Tri-band to see if I can just ditch the EAX80 all together, but no dice. I need to either return that router and swap my whole system out for a dedicated mesh network (and I will leave the Netgear brand if I do this), or I need to get this darn EAX80 to actually work, not make my network worse.
My #3 from my original post is what I am talking about. I need my devices to connect to the nearest device, not just the EAX80 the entire time. Crazy that its wireless signal from a different floor on a different side of the house overpowers the X6S on the same floor! This even happens when the EAX is two floors away!
- pkgaddSep 06, 2020Luminary
You're right, as I wasn't in physical proximity to my eax80, I had to extrapolate a bit.
If you use the android app, you can find the current IP address of your eax80 under network overview and tapping on the eax80 repeater icon. This will show you the MAC address and local IPv4 address of your EAX80, a webinterface is listening on this IP address and you can access it using the username and password you assigned to to your device earlier.
If you happen to be wirelessly connected to the BSSID of your EAX80 - or have connected a notebook via ethernet to one of its four ethernet ports, you can also use
http: <slash><slash> mywifiext <dot> net
"Firmware Update" is in the left menu frame, third entry from the top.
- strakercSep 06, 2020Aspirant
Thank you for the reply, although unfortunately none of this helps.
you can also use
Please see the first point of my original post; this website does not work for me in Friefox, Chrome, or Edge on either of my two computers tested, or on my phone for Firefox mobile or Chrome mobile.
Yeah, the default 192.168.1.250 - but this takes me to the same broken page above.
Please see the attached screenshot for what I mean by broken. This is what I see when I click the only button on the page - New Extender Setup - on any device, in any browser - no change at all (except for a minor URL change to http://mywifiext.local/ra_check_TC.htm). This is with Adblock+ disabled.- strakercSep 06, 2020Aspirant
Of course in trying different things, I did manage to just get a change. Despite having wireless turned off and being plugged directly into the Extender, if I go to the mywifiext URL, instead of 192.168.1.250, I get "You are not connected to your extender's WiFi network."
See attached screenshot. I then tried to turn wireless on and reconnect, but same issue.
