strakerc
Aug 23, 2020Aspirant
EAX80 - Cannot Access Settings
Man oh man, I have so many issues with my EAX80 / AX6000 Nighthawk Mesh Extender: 1. http://mywifiext.local/ loads, but clicking on the button "New Extender Setup" does nothing on Firefox, Chrome, o...
pkgadd
Sep 07, 2020Luminary
After changing the wireless channel on your main router (either manually or automatically after receiving a DFS event), it might a while for the repeater to follow suit (in the order of ~3-5 minutes). But yes, you definitely can change your wireless settings. Only if you do change ESSID/ PSK, you will have to reconfigure your repeater as well. In practice this means resetting the repeater.
Personally I can achieve 1000BASE-T linespeed over the EAX80 (the limit of its ethernet ports). In case of problems in the 5 GHz band, it might help to configure a non-DFS channel (ch36-ch48) for testing.
- strakercSep 07, 2020Aspirant
Why would the channel impact a speed restriction? Are you saying that is the case?
There are two 5GHz bands coming from my router, on channels 36 and 149.
