Noxivus
Feb 05, 2022Follower
EAX80 / AX6000 Power Adapter DC plug ID
What's the internal diameter of an EAX80 / AX6000's power DC plug? The OD is 5.5mm, but it is difficut to measure presicely the ID with a caliper. The ID seems to be either 2.1mm or 2.5mm. Due to...
Feb 06, 2022Guru - Experienced User
instead of buying a new power strip, why not buy a 6-12 inch power cord extention?
i've done that before. Its a much cheaper option and then you don't have to worry about sketchy power supplies.
- jamasampleFeb 14, 2022Aspirant
Thank you very much for your reply !! It is very valuable.
