PStafford
Feb 08, 2023Follower
EAX80 and BT Smarthub2 Issues
Hi I have full fibre BT broadband through a BT SmartHub2 router along with three BT wifi discs. My Nighthawk AX8 wi-fi extender seems to drop wifi connection regularly and even clash with the wi...
Feb 09, 2023Guru - Experienced User
Try powering off the BT wifi discs and see if the EAX stays stable. If they're setup in mesh, the extender can be hopping around from router to mesh discs and it causes problems.
It isn't recommended to mix mesh systems.
