VenomAX
Apr 01, 2020Tutor
EAX80 extender disconnects and crashes
I just purchased the AX8 Wifi Extender (EAX80) to mesh with my RAX80. The EAX80 crashes and disconnects every hour. Seems like a software issue. Noted that a new firmware release hasn't happened s...
Apr 01, 2020Guru - Experienced User
Have you tried a reset/reinstall?
When the firmware changes significanly, sometimes its needed after updating. And if its new, it probably went from release canadiate to production firmware.
- VenomAXApr 01, 2020Tutor
Yes, I did a hard reset twice on the Extender only.
- plemansApr 01, 2020Guru - Experienced User
Have you tried reloading the firmware? A reset only removes settings. If the firmware was corrupt, a re-install of the firmware can sometimes help with that.
which firmware version is the RAX on?
Yes, I have tried reloading the firmware. RAX just had an update Monday:
1.0.2.76.1.0.35.
I have unplugged the EAX80 for now, running on EX8000 with no issues.
