crnagoja
Jan 27, 2023Follower
eax80 loses connection
So netgear eax80. I properly connect the device to the router and the device works for about 1 hour and later the speed of device drops very low and device loses wifi signal and I have to reset it, m...
crnagoya
Jan 28, 2023Aspirant
Jan 29, 2023Guru - Experienced User
Fastlane is a good feature but if its making it stable, it usually means there was interference on the other channels.
Also something to check was if the router was using the dfs channels as if you have radar in the area, that'll cause drops as well.
