drmark986
May 09, 2020Aspirant
EAX80 Reception Issues
Has anyone with the nighthawk EAX80 Wi-Fi extender had issues where after a week or two, the signal light on the extended goes from white (perfect signal) to Amber? The speeds drop significantly. The ...
carys4
Jun 01, 2020Star
I've experienced this issue with my EAX80. It is a terrible unit. If you search "EAX80 problems" in this community you will see a lot of complaints about it. I don't know if the product was rushed out without proper firmware, but it is indeed problematic.
chuchi2k2
Aug 19, 2020Aspirant
I updated to firmware version 1.0.1.62 4 days ago and the signal light is off every time. With previous firmware the signal was on (amber, red or green) which indicated the quality of singal, but now, with the latest firmware i have not signal light. :(
- chuchi2k2Aug 22, 2020Aspirant
Today, i have revert the firmware to v. 1.0.0.36 and the signal light is back.
I don´t know why Netgear removed the signal light from the current firmware. It´s very useful for me.At a glance i can check the quality of the signal.
- drmark986Aug 22, 2020AspirantI have not updated to this firmware yet. Maybe the light was an oversight? Have you tried to update to the latest firmware again and see if it still turns the light off? I’m sure they wouldn’t get rid of it since it’s part of determining the best location for the device.
