RayFielding
Apr 25, 2023Aspirant
EAX80 Says "Your access point has no Internet access." but it's still working fine.
Hi I have a RAX120 router, two EAX80 and an EX6400 all three set up as access points. Everything is generally working well but all of the AP's display status of "Your access point has no Internet acc...
schumaku
Jul 06, 2023Guru - Experienced User
Have probably turned on How do I configure Access Control or MAC Filtering on my NETGEAR router using the router web interface? on your RAX120, and it's blocking the Internet access for the EAX80 and EX6400 LAN IP addresses? Note: This won't block other wireless (or wired devices) from getting their network access by these extenders. This is what you state as "it's still working fine".
- RayFieldingJul 07, 2023Aspirant
Many thanks for your help but unfortunately Access Control is turned off on the router and it always has been.
Interestingly, I did a reboot on all the AP's and for that last few weeks the EX6400 has been showing a connected status. However both the EAX80's still say "Your access point has no Internet access. Check to make sure that your router has an Internet connection."
I'm absolutely stumped.
