Billaban
Jul 14, 2023Guide
EAX80 Setup problem - no internet
Trying to setup EAX80 with Verizon MIFI. Tried two different MIFI units that are working fine and have internet connections. When I connect the EAX80 the internet connection is not realized. In ea...
- Jul 15, 2023
Billaban wrote:
Nothing about a Installation assistant in the Nighthawk documentation. I found it online but the instructions require a working internet connection to do:
Sure it is, you already discovered. Consult the fine Nighthawk AX8 8-Stream WiFi 6 Mesh Extender Model EAX80 User Manual and you find the "NETGEAR Installation Assistant" on page 16 Connect with the web browser setup.
Billaban wrote:
5 Enter (forum blocked URL) or 192.168.1.250 in the address bar of your browser.
The New Extender Setup page shows.Follow all steps. It does start with this:
1. On your WiFi-enabled computer or mobile device, open the WiFi connection
manager and locate and connect to the extender network called NETGEAR_EXT.This means using your computer or mobile associated with the factory default Wi-Fi on the EAX80.
If your EAX80 was configured before, use the reset button as shown on p.49.
Jul 14, 2023Guru - Experienced User
did you try using the installation assistant?
Does the mifi have ethernet out? Could always connect it hardwired in running in access point mode. It'll have a lot more power than the mifi's wifi
- BillabanJul 14, 2023Guide
The MIFIs do not have ethernet out port.
The New Extender Setup page shows.So that isn't going to get me anywhere since the root of the evil is I can't get a working internet connection via the EAX80.
- plemansJul 14, 2023Guru - Experienced User
You don't need a working internet connection to use the assistant.
You start it at factory, connect to the extender, and when you enter one of those addresses, it takes you through the assistant. I do it all the time.
- BillabanJul 15, 2023Guide
OK. This sounds promising but I'm lost as to what "You start it at factory," means. Can you elaborate? Thanks.
- schumakuJul 15, 2023Guru - Experienced User
- BillabanJul 16, 2023Guide
So after several factory resets and more than you want to read about I got it working. Thanks for the guidance. I'm modestly concerned that the whole setup (so far) has been flakey, e.g., several attempts to get expected behavior.
What I really want to accomplish is setting up a mesh system for our sprawling old house and EAX80 was purchased to provide the required port (that I don't have w/ a MIFI) to facilitate the mesh hardware connection. Is this going to work? Any suggestions or comments?
TIA
