Billaban
Jul 14, 2023Guide
EAX80 Setup problem - no internet
Trying to setup EAX80 with Verizon MIFI. Tried two different MIFI units that are working fine and have internet connections. When I connect the EAX80 the internet connection is not realized. In ea...
- Jul 15, 2023
Billaban wrote:
Nothing about a Installation assistant in the Nighthawk documentation. I found it online but the instructions require a working internet connection to do:
Sure it is, you already discovered. Consult the fine Nighthawk AX8 8-Stream WiFi 6 Mesh Extender Model EAX80 User Manual and you find the "NETGEAR Installation Assistant" on page 16 Connect with the web browser setup.
Billaban wrote:
5 Enter (forum blocked URL) or 192.168.1.250 in the address bar of your browser.
The New Extender Setup page shows.Follow all steps. It does start with this:
1. On your WiFi-enabled computer or mobile device, open the WiFi connection
manager and locate and connect to the extender network called NETGEAR_EXT.This means using your computer or mobile associated with the factory default Wi-Fi on the EAX80.
If your EAX80 was configured before, use the reset button as shown on p.49.
Billaban
Jul 14, 2023Guide
The MIFIs do not have ethernet out port.
So that isn't going to get me anywhere since the root of the evil is I can't get a working internet connection via the EAX80.
schumaku
Jul 15, 2023Guru - Experienced User
- BillabanJul 16, 2023Guide
So after several factory resets and more than you want to read about I got it working. Thanks for the guidance. I'm modestly concerned that the whole setup (so far) has been flakey, e.g., several attempts to get expected behavior.
What I really want to accomplish is setting up a mesh system for our sprawling old house and EAX80 was purchased to provide the required port (that I don't have w/ a MIFI) to facilitate the mesh hardware connection. Is this going to work? Any suggestions or comments?
TIA
- schumakuJul 20, 2023Guru - Experienced UserNot convinced sich a MIFI mobile WiFi (in absence of an Ethernet port) can supply a longer time reliable and performing Internet connection, especially considering all devices are causing doubled traffic on the wireless. This barely makes a replacement for a normal Ethernet router in my opinion.
- BillabanJul 22, 2023Guide
So I'm not sure how this will work either. Was going to get StarLink but the price has become just silly. We live in the country. Big house bed & breakfast. Have two MIFIs here and another at an additional house on the property. Have been using the MIFIs for years with few issues. Occasionally a guest will whine about the bandwidth but I know I can stream video when needed and I know that some people aren't happy unless they have something to **bleep** about. More than a few years ago I worked fulltime remote as a S/W systems engineer and rarely had issues with my full tunnel connection back to the office using just a MIFI.
The EAX80 and mesh setup is more about coverage than bandwidth expectation. The Netgear RBK753 is expected to arrive on Monday. The experiment will continue.
