dcinca
Jun 19, 2022Apprentice
EAX80 slow upload speed with RAX120
Hi everyone, Rax120 and Eax80 with wifi 6 on, 900ish/900ish Mbps download and upload are tested from Rax120. The upload is limited to 50ish Mpbs if the device is connected to Eax80, both wired an...
Jun 20, 2022Guru - Experienced User
When you log into the EAX80 using its ip address (and AX enabled) what is it showing for a connection strength back to the router? (a screen snip is sometimes more beneficial).
Also, what channel do you have the 5ghz set for on the RAX?
dcinca
Jun 22, 2022Apprentice
The connection is very good with wifi6 on, I also use Nighthawk App to log in to Eax80 and do a speed test, I got 900 download speed and 800 upload speed.
Here are more details:
I put Rax120 and Eax80 in the same room, about 4-5 meters away from each other. I connected my PC to Eax80 Lan. and my iPhone 12 pro max is connected to Eax80 5G.
Rax120 5G channel 44, HT160 on
If turn Eax80's wifi6 off:
Do a speed test on the phone, 278Mpbs down 67Mpbs up
Do a speed test on the PC, 501Mpbs down 75Mpbs up
If turn Eax80's wifi6 on:
Do a speed test on the phone, 284Mpbs down 306Mpbs up
Do a speed test on the PC, 666Mpbs down 674Mpbs up
If the PC is connected to Rax120 Lan: 914Mpbs down 814Mpbs up
If the phone is connected to Rax120 5G: 611Mpbs down 532Mpbs up
I also tried different firmware, channels and turn Rax120 to HT80. No difference from this result.
- dcincaJun 22, 2022Apprentice
I found a post about this problem: https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/EAX80/m-p/2126949#M47927
I tried some old firmware for Eax80, the upload speed from 5G of Eax80 goes extremely low.
- plemansJun 22, 2022Guru - Experienced User
Is the eax80 new? Or the RAX?
If so, you could be in your 90 day window of free support.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.- dcincaJun 24, 2022ApprenticeThey are not new, I just want Netgear know this bug and fix it later. How do I report it?
Thanks for helping.
