Sending-signals
Feb 27, 2024Tutor
EAX80 used as a WIFI extender goes offline 3 x per week
I have the Netgear Nighthawk EAX80 WIFI extender and it as of lately this last month suddenly going offline about 3 x per week. Once I restart it by power cycling the unit normal function is regained...
- Feb 27, 2024
I put the EAX80 into Fastlane 5ghz > 2.4ghz as you can see in the photo comparison.
The 2.4ghz signal strength was boosted to more than 2 x from 860m to 1729.
Hopefully this will resolve the dropped connections occurring way too often in the normal mode.
I will update this post in a few days for the results.
SSP2020
Jan 24, 2025Guide
Hi All,
Same thing Happeinung with my EAX80 Wifi Extender. I was using Both 2.4Ghz and 5 Ghz for Network Extender, but for the last 1 Month, I have seen the 2.4Ghz connected devices going offline very frequently, and I need to restart the extender many times to work again. I reset the Wi-Fi extender 2-3 times and updated the firmware, but I had the same issue.
EAX80 - AX6000 WiFi Range Extender
- Hardware Version: EAX80
- Firmware Version: V1.0.1.70_1.0.2
Now, the only solution is to use the Fast Lane, but you will get only 1 wifi range extender.
So I connected the Router to the Extender with 5Ghz, and Now the Extender will transmit only 2.4Ghz.
Instead of EAX80, I will use
wavlink AERIAL HD9S - WL-WN588HX3
Eero Outdoor 7
tp-link EAP650-Outdoor
Jan 25, 2025Guru - Experienced User
If the device is working fine in fastlane with the 5ghz functioning as backhaul and the 2.4ghz is solid, it tends to indicate the 2.4ghz backhaul connection is sketchy.
reason I say that, is when its in fastlane with the 5ghz backhaul, the 2.4ghz uses a different channel than the router. And y you say its stable and works fine. that indicates that its chip/broadcast is fine. But when its being used as a backhaul connection to the router, its not stable and drops, its indicating some issue with the connection back to the main router.
