Blabbs
Jul 10, 2020Aspirant
Effectiveness of PLW 1000v2 and PLW 1010v2
My need is to extend the power of my Router/Modem to a shed about 150 feet from the Router. Among other reasons for this need is to provide better quality Router and WiFi signal for my Arlo Security ...
Blabbs
I was told v2 is considerably more powerful than the "v1" and that v2 would likely work for that distance but v1 would definitely not. No one at Netgear seems to know either product. Simple questions as to the difference between PLW1000 and PLW1010 remain unanswered. As a Gearhead, I contacted the Gearhead people and for three separate calls, NO ONE could explain anything about the PLW1000 or PLW1010. What a waste of $200. The inablity to locate v2 is astonishing. Appears that Netgear simply doesn't care about the details in marketing the products.
Jul 10, 2020Guru - Experienced User
There isn't a whole lot of difference between the 2 versions. (plw1010 internally identicle to plw1000)
http://en.techinfodepot.shoutwiki.com/wiki/Netgear_PLW1010v2
http://en.techinfodepot.shoutwiki.com/wiki/Netgear_PLW1000
I'm not sure who told you one was significantly more powerful but in my experience, there isn't a big difference inbetween 2 versions of the same model. The difference is usually just sourcing parts or using a smaller/more efficient cpu type situation.
