rcooke1963
Sep 02, 2018Aspirant
Error Trying to update firmware on a WN2000RPT
Current Firmware info:
Hardware Version
WN2000RPT
Firmware Version
V1.0.0.24IC
GUI Language Version
V1.0.0.10
On the firmware tab, I click "Check for update" (s...
Lossitallet
Sep 02, 2018Guide
Following... :)
- StephenBSep 02, 2018Guru - Experienced User
Did you extract the img file from the zip (and then install the img file)?
The current firmware for the WN2000RPTv3 is here: http://www.downloads.netgear.com/files/GDC/WN2000RPTV3/WN2000RPTv3-V1.0.1.32.zip
- rcooke1963Sep 08, 2018Aspirant
This is my second attempt at replying! My first attempt never appeared, even though I got a "reply" badge for it.
Thank you for the input.
I did, indeed dowdnload the .32 latest ZIP file, unzip it, and then try to upload the IMG file. I even connected to the AP with a wire!
The automatic update does not work either, and I just tried to access the FTP address it is using. There are no files on the server! Has the FTP address changed?
- StephenBSep 08, 2018Guru - Experienced User
There's an automatic spam filter, it might have triggered. Mods are supposed to check it periodically, but sometimes it's just too much real spam in there for that to be practical.
I don't know (and also see no files in the update folder). Maybe DexterJB can suggest the next step?
