Tokyos
Jul 01, 2022Aspirant
Ethernet - EX6120 - Unidentified Network Windows 10 after setup.
So my EX6120 WiFi Range Extender is on đ, my windows 10 says unidentified network after setting it up with 192.168.1.250 once it reaches Click continue once connected device. The internet works cause...
Jul 02, 2022Guru - Experienced User
So its just the wired connection that doesn't work?
Did you try a different device hardwired into it?
What router is the extender connected to?
What firmware is on the extender?
