Ianbrown29
May 10, 2020Aspirant
Ethernet cable 60m from the router
I am trying to use the AC1200 EX6150 with an Ethernet cable on access point, I have the cable plugged in to the router after setting it up with a Ethernet short lead. The new position is 60m away from the router and it does not work.
Is the Ethernet cable too long for the signal?.
A decent cat5e or greater cable should be good up to 100m.
But it wouldn't be the first cable that had a nick in it or bad ends. Have you tested them
- Ianbrown29Aspirant
Not yet I will do a continuity test tomorrow, thanks for the info.
plemans wrote:A decent cat5e or greater cable should be good up to 100m.
