Bobbm2
Oct 27, 2021Guide
Ethernet cables and the X6 AC2200 range extender
Hello all, I have just bought a new house but my new garage/workshop is too far away to receive a wifi signal directly from the router or via the extender. I have a shed load of ethernet cable and a...
- Oct 29, 2021
The EX7700 is a pretty rock solid extender.
Unless you have wifi 6 (AX) devices, the EX7700 is still going to be one of the best performing extenders/access points out there.
And when wired in, its triband. So its got plenty of bandwidth.
Like I said, unless you're looking at going wifi 6 and its meeting your needs, I'd keep using it.
Oct 27, 2021Guru - Experienced User
What AC2200 is it? (AC2200 is a speed not a model)
Most of the range extenders have an access point mode that lets you wire them into the router.
If you go to the support site and type in your model number, it'll take you to guides/manuals/firmware. If yours supports access point mode, it'll be in the manual.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Bobbm2
Oct 27, 2021Guide
Thanks for the super fast reply plemens. It's an EX7700 model. I've had a look through everything but can't work out how to set it up as an access point on the Netgear Nighthawk app. It doesn't ask me, like it says it should, if I want to set up an access point. Should I reset the extender and have another go? Would it be easier if I set up a different Wi-fi SSID?
- plemansOct 27, 2021Guru - Experienced User
to set it up in access point mode, use the installation assistant and not the app.
That'll give you the option of setting up in extender mode or access point mode
- Bobbm2Oct 28, 2021Guide
Hi Plemens. I tried setting up using your suggestion. Plugged in two different Ethernet cables, made sure that the one going to the router was in the WAN socket, used both sockets on the extender, logged in to the extended network at 2.4G and 5G and pressed the button saying to set up in access point mode. But kept on getting the same, 'cannot connect to the internet' message. I really have no idea what I'm doing wrong. I'm not a dummy when it comes to PCs but this is driving me nuts. It should be so simple.
Bob
- plemansOct 28, 2021Guru - Experienced User
The EX7700 shouldn't be plugged into a wan port on the router/gateway.
It should go from the Lan port on the router to a port on the EX7700.
If the 2nd connection you have hooked up is going to the pc you're using for setup, thats fine. If not, disconnect it.
What router are you connecting it to?
