Ratickle1
Jan 08, 2018Tutor
Ethernet conection to AC3000- X6S Extender
I'm trying to find out if the X6S can be connected with an ethernet cable but be used as an extension of the same SSID. I cannot find it anywhere in the documentation or online, or when I called supp...
TheEther
Jan 08, 2018Guru
You are looking for Access Point mode.
http://www.downloads.netgear.com/files/GDC/EX8000/EX8000_UM_EN.pdf
Ratickle1
Jan 08, 2018Tutor
Thanks, But I've read that part several times before posting and it is still unclear to me. It appears to me that when the extender is connected in access point mode it only works as an extender with a new SSID. You completely lose the seamless extension of the existing network. So, as you move from one end of the house to the other the device being used switches from one WIFI network to another. It appears, when I read it, the only way to keep a seamless network is to use it in the WIFI connection mode.
I hope I'm wrong, but that it the way it appears to me. If so, there is no reason to buy this latest extender unless you want to connect it wirelessly, which loses one 5g channel as it will be exclusively used to connect the extender to the router.
Am I missing something when I read it?
- TheEtherJan 08, 2018GuruYou can change the SSID to match the existing network. See the section "Change the WiFi Network Name" in the manual.
- Ratickle1Jan 08, 2018Tutor
So, I can link the X6S to the main AC2600 via ethernet cable. Then name both with the same SSID via enable one WIFI name, and I will have one seamless WIFI network that I can wander all over the house and will stay connected to one, (pretty powerful 3 band ), network because I did not use one of the bands to connect the extender to the router? And the extender can also handle 3 ethernet connected devices that will also not hog WIFI speeds?
If this is true, from what you know should I connect both via CAT6 versus CAT5e cable? Or will that make no difference in speeds?
- TheEtherJan 09, 2018Guru
I've never used an EX8000, so I cannot confirm that the 3rd band will be available for clients to use.
Devices usually decide on their own when to switch Wi-Fi connections. Unfortunately, many devices will not switch when you expect them to. A lot of devices are very sticky and won't switch until the connection is close to unusable.
There should be no difference between a Cat6 and Cat5e cable.
