AlexSotheran's avatar
Nov 24, 2021
Ethernet connection not working on WiFi Booster Range Extender
Hi All, I have been using a Netgear wifi extender (EX2700 N300) in my loft with the ethernet cable into a laptop. Until recently it has worked fine, but now the interent connection has started to dro...
  • plemans's avatar
    Nov 24, 2021
    try factory resetting it and reinstalling it using the installation assistant and NOT wps. See if that works.
