AlexSotheran
Nov 24, 2021Guide
Ethernet connection not working on WiFi Booster Range Extender
Hi All, I have been using a Netgear wifi extender (EX2700 N300) in my loft with the ethernet cable into a laptop. Until recently it has worked fine, but now the interent connection has started to dro...
- Nov 24, 2021
try factory resetting it and reinstalling it using the installation assistant and NOT wps. See if that works.
AlexSotheran
Nov 24, 2021Guide
Thank you, that appears to have worked!
plemans wrote:try factory resetting it and reinstalling it using the installation assistant and NOT wps. See if that works.
Nov 24, 2021Guru - Experienced User
Glad to hear it worked!
