Jun 22, 2020Follower
EX 2700 Can't get WPS to stop flashing
Hi, hope don't come off as too stupid, I am following the steps...I want to see if this will help with the firestick plugged in behind the TV in another room. It should, right? I plugged in the EX...
Jun 23, 2020Guru - Experienced User
Try setting up the ex2700 using the smart installation method and not using wps. WPS between different device manufacturers can get coded different and not always work. Which is why there's also the smart installation method.
