GMChambers
Nov 02, 2021Initiate
EX 7500 Set-up/Security Question
Trying to perform the initial set-up of my EX7500 extender. I have Century Link internet and use a Zyxel C3000Z modem/router combo. The EX7500 instructions state "If your router's wifi security i...
- Nov 02, 2021
You can use it. theres a wpa2-personal and wpa2-enterprise.
Your C3000 will use wpa2-personal. You'll be able to connect and set it up.
Nov 02, 2021Guru - Experienced User
- GMChambersNov 02, 2021Initiate
Awesome... thanks so much!
- plemansNov 02, 2021Guru - Experienced User
Let me know if you have issues setting it up and I'll be happy to help!
