GMChambers's avatar
GMChambers
Initiate
Nov 02, 2021
EX 7500 Set-up/Security Question
Trying to perform the initial set-up of my EX7500 extender. I have Century Link internet and use a Zyxel C3000Z modem/router combo.   The EX7500 instructions state "If your router's wifi security i...
  • plemans's avatar
    Nov 02, 2021
    You can use it. theres a wpa2-personal and wpa2-enterprise.
    Your C3000 will use wpa2-personal. You'll be able to connect and set it up.
