Red193
Feb 19, 2023Follower
Ex 7700 won't connect
When trying to set up range extender it just says connection failed and gives no reason as to why or how to fix it
amaradevid
Feb 20, 2023Star
Make sure the Netgear EX7700 extender is in range of your wireless router. Make sure ethernet cable are properly connected. Reset the extender to its factory default settings, and try setting it up again from scratch. Make sure you are entering the correct Network name and password for your wireless network when prompted during the setup process. Update the firmware of your Netgear EX7700 extender to the latest version.
