thehulk's avatar
thehulk
EX 8000 - does it support 160 mhz channel for use with intel 9260 160 mhz?
firmware: V1.0.1.180
model : ex8000
region: north america
how can i make use of the 1.73 gbs 5ghz channel in ap mode?
i am currently using intel 9260 160 mhz which is capable of 1.73 gbs.
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello thehulk - The 1.73gbs  is dedicated to the backhaul connection only and is inaccessible.
    ~Christian
    • schumaku's avatar
      schumaku
      That's an expensive loss of capability in AP mode isn't it?
      • thehulk's avatar
        thehulk
        Then why do i have an option to change radio 3 (5 Ghz) to 1.7 Gbs speed if it is inaccessable?
        There must be a way to achieve 1.7 Gbs or the option should not exist in ap mode.
