Sony848
Jul 17, 2021Tutor
EX2700 - Can I use an Ethernet Junction Box to run 3 Cameras?
OK, Here Goes..... I have a Netgear EX2700 WiFi Extenser in my garage....about 50 Ft from my Router. It picks up a very strong signal. So, Can I attach the ethernet cable from the extender to an e...
- Jul 20, 2021Thonks, I'll updte in a week or so.
Sony848
Jul 20, 2021Tutor
The "box" I ordered is a:
TP-Link 5 Port Gigabit Ethernet Network Switch Ethernet Splitter TL-SG1005D
which has a Rj5 ethernet Input and 4 ethernet outputs.
It is powered via 110v plug-in.
I expect that this will work fine for this application.
Jul 20, 2021Guru - Experienced User
should work fine
- Sony848Jul 20, 2021TutorThonks, I'll updte in a week or so.
- Sony848Aug 17, 2021Tutor
UPDATE:
Here's what I bought:
I hooked up 3 network cameras and a desktop computer.
All work great, Speed is at Max.
I was able to elimonate several WiFi Extenders by doing this.
Thanks to all for your replys.
- plemansAug 17, 2021Guru - Experienced User
Glad its working well!
