anmcg1
Apr 17, 2020Aspirant
EX2700 - Really slow speeds
Hi all, Wondering if someone could help me with an issue I have with my NETGEAR EX2700. When I am connected to my main router (located in the living room), I am getting download speeds in exc...
Apr 17, 2020Guru - Experienced User
the link speed isn't the same as throughput speed. 5ghz signals usually see around roughly 55% reduction in speed in comparison to its link speed. 2.4ghz is even worse than this because of network congestion, different signals, and interference.
Plus extenders by the very nature of how they work, reduce throughput by roughly 50% and increase latency. That's because they have the recieve and then retransmit on the same radio chip. And they can't transmit while recieving. (tribands help reduce this a lot).
20mbps is actually what can usually be expected from 2.4ghz N300 extenders running in extender mode.
I would refer you to smallnetbuilders N300 extender reviews/rankings. The average throughput is right around the 20mbps.
https://www.smallnetbuilder.com/tools/rankers/wireless-extender/ranking/N300/rev1/238
If you want faster speeds from an extender, I'd refer you either to a dual band or for the best speeds, a triband extender.
- anmcg1Apr 25, 2020AspirantThanks for your reply. Could you possibly recommend a particular dual or tri band extender and if so, what speeds would I expect to see on these?
- plemansApr 26, 2020Guru - Experienced User
I would shoot for a tri-band. I've got an EX8000 and it works great. again, you still take a little speed hit because you're still having to go through another device but its greatly mitigated using tri-band fastlane.
that'd be the EX7300, EX7700, EX8000.
