Joe3445
Apr 27, 2020Tutor
EX2700- extender Issues
I have a new Netgear modem and router so we could ditch our ISP’s rental. I was also hoping it would improve our WiFi signal in our bedroom about 70ft away from the router and our downstairs office wh...
Joe3445
Apr 27, 2020Tutor
Thanks for your reply. Some comments from yours.
2. Did you mean “basic” extender not “back”?
Am I better at off buying a new extender with 5ghz capabilities? I’ve moved the extender throughout the house and even ten feet away from the router I’m getting weak signals. For reference the things I need WiFi extended for for is a fire stick in the bedroom (70ft. Away) a WiFi printer and VPN connecting laptop downstairs (70 ft away as well but downstairs directly below the bedroom).
Thanks for your help.
Apr 27, 2020Guru - Experienced User
Yes, basic.
What are the interior walls of your home?
certain materials block wifi extremely well and extenders aren't always the best option. these include: plaster lathe, adobe, brick, concrete, metal studs/metal
What speeds were you getting?
What speeds can you get from the primary router around the home?
- Joe3445Apr 27, 2020TutorIt’s mostly drywall and wooden frames for the interior.
I’m getting over 200mbps by the router. The extender best case gets ten if I have it relatively close to the router and 5-6 if it’s downstairs.
