NetTown's avatar
NetTown
EX2700 as direct connect Access Point from Router?
I'm trying to connect my EX2700/N300 directly (hardwired with a CAT5 ethernet cable)  to my CenturyTel dsl modem/router via the N300 ethernet port so as to use the N300 as an access point for my router's WiFi. A previous discussion here suggests that "all extenders can function as wireless APs" though I may be reading that wrong.
I did open a support case with NEATGEAR to ask if the N300 could do this and they said "yes" but couldn't provide setup or config steps.
Any guidance would be appreciated.
Thanks
  • plemans's avatar
    I don't specifically have this one. Saying that, all my research shows it doesn't work as a wired AP. You'd need to go up a series for this function.  The ethernet port is only for connecting a computer/wired device requiring internet to it.
    The post you linked to stated all extenders can act as a wireless ap meaning they connect back to the router wireless and act as an access point. Not wired access point. its in the 3rd post at the bottom. I'm not sure why support told you it would function as a wired AP. Maybe it was a misunderstanding in what you were trying to do.
    If someone else has this and has gotten it working somehow, please correct me. :)
    • NetTown's avatar
      NetTown
      Thank you for the reply. In my support case converstaion I did spell it out (written in the submission while on hold) and communicate it verbally a couple of times but agree communication lapse is possible. I even asked them if I needed to buy some other product and they said that the EX2700 N300 would do it.
      I am more than happy to buy the correct piece of equipment and just need to know what that is and how to config/set it up.
      Would "going up a series" mean the EX3700? Or something else?
      • plemans's avatar
        The faqs for the ex3700 shows it has the option of wired access point so that's a safe bet if that's your goal.
