desertsailor
Mar 09, 2020Initiate
EX2700 can not "see" my router Network
My EX 2700 extender was working nicely with my TP-Link Archer C9. It stopped connecting after I made a reboot of my router. The extender keeps failing to make a connection through WPS. When using ...
- Mar 09, 2020
What 2.4ghz wireless channel is the C9 broadcasting on?
Try changing it to 1-6-11.
Mar 09, 2020Guru - Experienced User
desertsailor
WOW!!
That did it. I had switched to ch.13 to help reduce interference from neighbors đ .
Thank you very much for your help.
