Billblackwell
Aug 16, 2019Aspirant
EX2700 Connected No Internet
Device has been working fine for months and now it connects like I always did but now it says No Internet. I have updated the firmware on my Router to the newest thinking that may fix the problem. S...
Billblackwell
Aug 22, 2019Aspirant
Installed V1.0.1.52 firmware
Still shows the same.
All lights are green
Christian_R
Aug 22, 2019NETGEAR Employee Retired
Billblackwell - Factory reset the extender by pressing on the small black button using a pin for 15+ seconds then join the NETGEAR_EXT wifi network using a phone or laptop. After you connect to the NETGEAR_EXT network with your phone or laptop, browse to www.mywifiext.net and follow the setup instructions.
Please let me know during what step of this process you run into issues with. I would recommend setting up the extender in the same room as the router before moving it to the designated area.
~Christian
- BillblackwellAug 23, 2019Aspirant
Went all the way through your instructions.
It acts like everything goes good (login etc)
After login......
Still the same. I bought a new one and it works fine.
Gonna toss this one.
Thanks for your efforts....
