aussiescall
May 05, 2021Tutor
ex2700 connects to router but doesn't accept password
The password hasn't changed but it will not accept it. What can I do please? I've had to move it closer to router so it now connects but won't accept the routers password. Quite frustrating and annoy...
May 05, 2021Guru - Experienced User
Are you setting it up using wps or using the installation assistant?
What router are you connecting it to?
- aussiescallMay 05, 2021TutorSet it up using WPS. WPS lights were all green non flashing on both router and extender. It came up with my network name with EXT and asked for password but wouldn't accept it. Router is Technicolour TG588v v2
- plemansMay 05, 2021Guru - Experienced User
Technicolor has horrible wps support.
Try factory resetting the extender and installing it using the installation assistant and NOT wps.
To reset, push and hold reset for 7-15 seconds while the extender is powered on.
- aussiescallMay 06, 2021TutorI went to the page the instructions state (won't let me post its name here but have attached picture of instructions) but can't see New extender setup button so do get create account page displayinh so can't follow netgears instructions. Have they changed the page or the instructions. Feel so near yet so far
