SnapperStephen
Apr 08, 2021Initiate
EX2700 Device Connection
Hello from the UK. I have just purchased a wifi extender EX2700. I have got as far as connecting the router which was straightforward enough. My problem is connecting the devices. It is stated in t...
Apr 08, 2021Guru - Experienced User
what router did you connect it to?
Did you connect it using wps or using the installation assistant?
- SnapperStephenApr 08, 2021Initiate
Hello and thank you for the response.
I'm connected to a Technicolor router initially via WPS. When that failed i tried the connection assistant. This took some sorting as the site would not launch in Chrome, Edge no problem and registered and set up. The laptop connected to the _EXT no problem with the router password.
