SnapperStephen
Apr 08, 2021Initiate
EX2700 Device Connection
Hello from the UK. I have just purchased a wifi extender EX2700. I have got as far as connecting the router which was straightforward enough. My problem is connecting the devices. It is stated in t...
Apr 08, 2021Guru - Experienced User
what router did you connect it to?
Did you connect it using wps or using the installation assistant?
SnapperStephen
Hello and thank you for the response.
I'm connected to a Technicolor router initially via WPS. When that failed i tried the connection assistant. This took some sorting as the site would not launch in Chrome, Edge no problem and registered and set up. The laptop connected to the _EXT no problem with the router password.
