karen_f's avatar
karen_f
EX2700 Does not broadcast SSID
My EX2700 was working fine.  Then I got a new wireless router and tried to set up the extender again.  However, none of the three devices in our home "see" the extender.  NETGEAR_EXT does not show up as a device to connect to.  My laptop has no ethernet jack so I cannot make a hardwired connection (and the other two devices are phones).  I have tried a factory reset, but that changes nothing.  The Power and WPS lights are green.
Thanks in advance for any suggestions.
  • plemans's avatar
    What router are you trying to connect it to?
    are you setting up the extender via wps or the installation wizard?
    did you factory reset the extender to re-run setup?
    • karen_f's avatar
      karen_f
      Thank you for your reply.  I did indeed press the reset button on the device.
      My router is a Linksys EA7300, but I haven't reached the step of trying to connect to it because I cannot connect to the device (the extender) itself.  I was trying to use the wizard, but could not proceed because the extender does not broadcast the SSID.
      • plemans's avatar
        1. When many hit the reset they don't hold it. While its powered on, push and hold for 7-15 seconds.
        2. What are the led's on it doing? (all of them, color/blinking/etc)
        3. You can buy a cheap usb----ethernet adapter. Always handy to have around
        4. or borrow a computer to connect.
