Rialbo
Apr 18, 2017Aspirant
EX2700 Extender Connected Device Bypasses Main Router Site Blocking
This is a great device in extending Nighthawk R7000 router coverage but ..... Sad to just discover that transmissions from browsers on devices connected through the Extender are bypassing the Site /...
DarrenM
Apr 21, 2017Sr. NETGEAR Moderator
Hello Rialbo
What you will need to do is log in to your router and find the DNS server that is being used this is typically shown in the Internet settings copy this down. Next you will want to log into your extender and go to Internet setup and switch it to Use a static Ip address here you will want to change the DNS to the same DNS that the router is using. This should make the Parental controls work on the extender.
DarrenM
